Home > Forums > Software User Forums > FLOW-3D
erroe correction
Old   March 6, 2017, 04:20
Default erroe correction
Aravinth
Aravinth15 is on a distinguished road
how to fix this error in simulation.
i'm new to flow 3D
Solver Messages:
warning from shallow water model:
cell i= 69, j= 89, k= 2, in mesh block 2 is 90% full,
excessive volume error may occur if it fills up completely,
try increasing cell size in z-direction
Aravinth15 is offline   Reply With Quote
Old   March 6, 2017, 12:06
brian
bfox48 is on a distinguished road
The shallow water model setup has some specific requirements to make it compatible with 3D mesh blocks. The mesh needs to be 2 cells high, and the bottom cell needs to be large enough to contain all of the fluid. Think of the top cell as a ghost cell... it needs to be there for the model to run but it has no interaction with the fluid.
Check out the user manual for more information on the shallow water model, and then review your mesh setup.
bfox48 is offline   Reply With Quote
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 22:51
Divergence detected in AMG solver: pressure correction CMICT FLUENT 4 June 14, 2016 13:08
SIMPLE algorithm does not converge when using old pressure (correction) values andreasp Main CFD Forum 3 February 9, 2016 22:18
Production correction or curvature correction in the SST model Ang CFX 2 May 20, 2014 21:50
Star ccm 9.02 - unsteady flux dissipation correction fivos STAR-CCM+ 4 April 28, 2014 10:37
