Home > Forums > Software User Forums > FLOW-3D
how to run Flow3Dv11.2 in Linux by using textual interface?
Old   February 27, 2017, 21:03
Smile how to run Flow3Dv11.2 in Linux by using textual interface?
asd
PICK is on a distinguished road
I can run it in graphical interfaces of linux. But I dont know how to run it by using textual interface. Somebody konws it or what commands in it ?
PICK is offline   Reply With Quote
Old   February 28, 2017, 05:40
ajv
AJVellinga
ajv is on a distinguished road
Hi PICK,
You are able to run your prepin.file by using another script, I think there should be an example one in /flow3d/v11.2/local/
The name of the example script is "runall"
Hope this helps
ajv
ajv is offline   Reply With Quote
Old   February 28, 2017, 09:11
Smile command not found
asd
Originally Posted by ajv View Post
Hi PICK,
Hope this helps
ajv
Thank you! I have already tried it,but the system told “command not found” . You can see my screenshot---"Linux.png". what should I do?
flow3d linux
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Run Fortran exe files on Linux (generated in Windows) imanmirzaii Lounge 1 November 8, 2014 16:57
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
Parallel run fail in CFX5.7.1 in Linux FC.4 Begonia CFX 1 August 2, 2005 09:03
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
