February 8, 2017, 09:06 |
Non-time-dependent results
Eduardo
Hi, I'm simulating a flood, I need to know how to get the result of the maximum flood in the entire topography. In Flowsight and Flow-3d I only obtain time-dependent results, in this case the result I need occurs at different times. Is there any way to generate this result ??
thanks for your help |
February 8, 2017, 17:15 |
If you activate the "hydraulic data" there is a variable called maximum flow depth, which is what I think you want. You could also output your selected data to a time frequency so you can capture the flood wave moving through the domain. Using this result, you can post-process to find your max flood elevation at each location. This might result in a very large file size, so also look into using history probes if you only need to get the max elevations at a few locations.
[solidMechanics] solidMechanics gear contact in rotation | nlc | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 3 | January 11, 2015 07:41 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 23:40 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
