Home > Forums > Software User Forums > FLOW-3D
Mass & Momentum sources
Old   January 26, 2017, 11:01
Unhappy Mass & Momentum sources
Neeharika
Kittu is on a distinguished road
I want to know whether a inlet pipe with certain velocity can be given in the domain without creating a geometry. Mass source need a geometry to provide a static pressure and velocity at the inlet but my inlet diameter is very small compared to my domain. Mass momentum source will vary the flow rate and make my source into sink during simulation. I would like to know if there is any way to give a constant velocity inlet without geometry using mass momentum source. Help !!!
Kittu is offline   Reply With Quote
Old   February 6, 2017, 13:26
brian
bfox48 is on a distinguished road
You can use mass-momentum sources. In the flow specification, select 'Velocity', and then enter the component values.
bfox48 is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 21:47
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Add total mass using sources to multi component fluids mullenc525 CFX 1 February 5, 2011 05:56
