Home > Forums > Software User Forums > FLOW-3D
Number of mesh blocks limited?
Old   September 14, 2016, 12:27
Default Number of mesh blocks limited?
Chris
chripasch is on a distinguished road
Dear experts,
I would like to simulate a situation where I use 88 mesh blocks to model precisely a flow field as an inlet boundary condition. That works out in a other case with 62 mesh blocks. However, the console says "abnormal exit from postprocessor" after successfully (at least it looks like) performing the simulation with 88 mesh blocks. Starting the analysis ends up in a pop-up saying "Failed to generate results file information". Furthermore, the data cannot be used as restart data, the console says "error opening restart source file" - "error code 22".
I started to decrease the block number and figured out that the problem vanishes as soon as the mesh block number becomes 78 or less.
Does anyone of you experience that problem or does anyone know how to solve this? Plese keep in mind: Yes, I really need that 88 blocks ;-)
Thanks a lot in advance
chripasch is offline   Reply With Quote
Old   September 16, 2016, 07:43
user01's Avatar
Reynolds
user01 is on a distinguished road
Originally Posted by chripasch View Post
Dear experts,
If you upload the files I will check it. Donīt forget the geometry and the .prepin file.
Regards.
A wife asks her husband, a software engineer...
"Could you please go shopping for me and buy one carton of milk, and if they have eggs, get 6!" A short time later the husband comes back with 6 cartons of milk. The wife asks him, "Why the hell did you buy 6 cartons of milk?" He replied, "They had eggs."
user01 is offline   Reply With Quote
Old   October 4, 2016, 11:13
Chris
Sorry for not replying quite a long time.
Although the problem still exists, I found a way to reduce the mesh block number for the problem I investigate. In this case, it works out for me.
Sending all my simulation files would overload your mailbox
Anyhow, thanks a lot for your offer and help.
Best regards
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 09:07
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 15:53
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
