Home > Forums > Software User Forums > FLOW-3D
Problem of water from nowhere
Old   July 26, 2016, 09:32
Default Problem of water from nowhere
nels0n is on a distinguished road
I'm simulating from a restart simulation with no problem a flow over a flood evacuator in Flow 3D v11.1 and I set the following boundary limit:
xmin: Specified pressure, Stagnation pressure, Fluid elevation
xmax: Specified pressure, Stagnation pressure,
ymax: Specified pressure, Stagnation pressure, Fluid elevation
ymin: symmetry
zmin: symmetry
zmax:symmetry
I've already done this simulation for a case and I obtained result with no problem.
I keep the same setup than before whith this time the bottom of the gate 0.3m higher but I obtain a sort of waterfall from the back of the right gate whith no physical explanation. No leaks are appearing, and fluid elevation is set 0.5m above the restart simulation. I've attached a picture of this problem after 140s of simulation time
Thanks for your answer
nels0n is offline   Reply With Quote
Old   July 29, 2016, 19:03
thunde47
thunde47 is on a distinguished road
Cant see your picture. Also, share your prepin if you want me to have a look.
thunde47 is offline   Reply With Quote
problem with two phase flow (air injected in water) miles_davis OpenFOAM 15 March 31, 2021 10:36
Deep Water Wave Generation Problem Mahdi_co_1368 CFX 3 March 11, 2015 06:23
Problem in implementation of Shallow water equation DeliriousPsycho Main CFD Forum 1 December 23, 2011 08:01
Problem about water spliting chemical reaction !! Luke FLUENT 5 June 13, 2006 00:26
Problem about water decreased and boundary changed Luke FLUENT 2 June 6, 2006 15:54
