June 29, 2016, 12:09 |
Boundary conditions for sediment scour model
Chris
Rep Power: 12 |
Dear experts,
I am wondering if and how to define boundary conditions when using the sediment scour module of FLOW-3D (v11.1.3.1). When sediment is added, the model somehow needs to have information on the sediments e.g. leaving the domain to solve the advection-diffusion-equation. I know that one can set sediment concentrations and this is totally clear to me at the upstream boundary. But how to handle the downstream boundary? Is sediment (bed load and suspended load) "automatically" transferred out of the domain? I quite often make the experience that sediment accumulates shortly upstream of the downstream end of the domain. Thanks a lot for your help and valuable advises |
July 8, 2016, 07:21 |
AJVellinga
Rep Power: 10 |
If you use an outflow boundary condition the fluid (+sediment) should just be able to exit your simulated domain.
November 3, 2016, 12:15 |
hewida
Rep Power: 10 |
what about the finish time and the time step
as if i want to simulate two hours how can i use big time step without error |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 12:14 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 08:15 |
