Home > Forums > Software User Forums > FLOW-3D
"Freezing" flow velocity field
Old   June 17, 2016, 07:18
Default "Freezing" flow velocity field
Chris
chripasch is on a distinguished road
Dear all,
is there a possibilitiy to "freeze" a calculated flow velocity field (e.g. in a straight channel) to use it in a subsequent simulation adding sediments with FLOW-3D v11.1.3.1 ? The idea is to save computational costs by not recalculating the velocity field. I am aware of possible changes in geometry and thus on the flow field by means of deposition or the like.
Or will the software/solver anyhow crash due to this respectively not allow simulations without recalculating flow velocities?
Thanks for your help and best regards
chr+s
chripasch is offline   Reply With Quote
Old   June 24, 2016, 17:51
thunde47
thunde47 is on a distinguished road
Use restart simulation to use results (including velocity field) from any time frame from an already ran simulation.
Be careful about what changes you make for practical results.
thunde47 is offline   Reply With Quote
Old   June 27, 2016, 05:27
Chris
@ thunde47: Thanks for your answer, but I am not sure if this is exactly what I searched for: Will using the restart option prevent recalculating the flow field in the following restart calculation?
Old   June 29, 2016, 05:37
user01's Avatar
Reynolds
user01 is on a distinguished road
@chripasch: You can do a first simulation and with that result and checking the time step you need, define the restart simulation. My advice is not the change the surrounding geometry, I mean, when you load the restart file ensure that the geometry is the same in both cases. In that case you won´t loss information. After loading the restart file let the program calculate some iterations and check what is program is doing to be sure….
Feel free to ask!
Regards.
user01 is offline   Reply With Quote
Old   June 29, 2016, 05:39
user01's Avatar
Reynolds
Definitely yes.
Old   June 29, 2016, 12:05
Chris
Thanks for your replies, now it became clear to me.
Thread can be closed.
Velocity field not divergence-free for incompressible flow vkrwth FLUENT 0 May 18, 2016 07:15
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 18:24
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Flow field measurement in turbomachinery! Wanlai Lin Main CFD Forum 3 September 3, 1999 13:06
