Home > Forums > Software User Forums > FLOW-3D
free surface indicator
Old   June 9, 2016, 11:32
Default free surface indicator
thixo is on a distinguished road
I am trying to calculate an Integral over the surface of a casting process using FlowSight.
I only want to calculate the free surface, not the one touching the wall. Is there a good way of doing that?
Until now I have calculated a variable over pressure (=1 if pressure low enough,. else =0) and multiplied that by the variable of interest. However, this does not always lead to stable results.
Additional question: When surface integrals are plotted vs time, the values are not the ones that are shown in the induvidual time frames. Is it possible to recieve correct plots for surfaces?
Thank you
thixo is offline   Reply With Quote
how to capture free surface cells? MichaelVS FLUENT 1 June 10, 2015 03:18
Floating dok on waves: free surface divergence Galchenko CFX 3 September 11, 2014 19:04
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 19:13
Equilibrium of a free surface under surface tensio Ryan Main CFD Forum 1 August 7, 2001 17:14
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 22:03
