Home > Forums > Software User Forums > FLOW-3D
Mass source 2nd fluid
Old   June 3, 2016, 06:18
Default Mass source 2nd fluid
ajv
AJVellinga
ajv is on a distinguished road
Hi all,
I am setting up a simulation with mass sources, and I want the second phase (fluid) to be injected into my systems trough a mass-source. It however appears that the mass-source can only deal with the first phase, despite defining it in the GUI as 2nd phase. Flow3d changes the prepin-file during pre-processing to change the mass-source of the fluid from the 2nd to the 1st fluid. Has anyone else experienced this issue, and found a way around it?
cheers
AJV
ajv is offline   Reply With Quote
Old   September 13, 2016, 11:00
Masoud Ravan
masoud.ravan is on a distinguished road
Originally Posted by ajv View Post
Hi all,
cheers
AJV
Hi dear AJV!
That is my problem too. Did you find any way...?
Thanks,
masoud.ravan is offline   Reply With Quote
Old   September 13, 2016, 11:06
ajv
AJVellinga
Hi Masoud
Unfortunately I have not been able to find a really good workaround. In my case I wanted to create a saline underflow (under fresh water). As an alternative I used the sediment scour module to make the water more dense with a sediment particle size so small that they settle extremely slowly. Not ideal, but it did work to some degree. I abandoned to project I was working on for this in the end so cannot tell you how valid the results were.
If you find a solution I'd love to hear from you.
Cheers
AJV
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
