Home > Forums > Software User Forums > FLOW-3D
Problems for Stepped Spillways Modelling
Like Tree2Likes
Old   May 11, 2020, 12:39
Najam us Saqib
Najam_us_Saqib_Fraz is on a distinguished road
Thank you for the reply.Actually my model height is 1m,and width is 300 cm.My model have 13 steps with first 5 steps having different heights.For this I chosed 10 mm mesh size.I have a smallest step of height 20 mm.What size would you recommend and what model should I use to get it right.I am trying to draw the pressure profiles on different steps.
Najam_us_Saqib_Fraz is offline   Reply With Quote
Old   May 11, 2020, 18:41
Ysmn
elyasmin is on a distinguished road
Check if you can see the steps properly after favoring the solid.
elyasmin is offline   Reply With Quote
Old   May 12, 2020, 02:55
Najam us Saqib
Yes..I favored the solid.There are first few steps (1 or 2 ) whose shape looks a bit distorted.I am trying to reduce the mesh size but as I reduce the mesh size the flow starts to jump over the steps. In fact it must skim,but with the finer mesh it starts to jump and do not follow the flow pattern.
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Problems when compile SU2 v4.X with openmpi BopngMa SU2 1 September 6, 2015 07:30
Problems when modelling flow through syringe, error in dynamic initialization Sudarsan1805 FLUENT 3 September 2, 2015 03:19
Some problems with Star CD Micha Siemens 0 August 6, 2003 14:55
liquid/solide phase change problems mehdi fteity Main CFD Forum 3 September 14, 2000 22:44
