Home > Forums > Software User Forums > FLOW-3D
Conforming mesh
Old   February 13, 2016, 11:51
Default Conforming mesh
Fábio
FUDM is on a distinguished road
I´m using Flow-3D version 11, where I intend to simulate a house's ventilation system. For that, I created a full-scale model of the house, including all the ventilation pipes. My problem is in the definition of the ventilation grids, where air enters the rooms. These grids are extremely small when compared to the entire house, containing small holes with approximately 6 to 9 mm. Using simple multi-block cells does not work considering the cell size ratio between the cell blocks that define the house (with relatively big cells) and those needed to define the grids (with extremely small cells).
I've heard of the conforming mesh option in the latest versions of Flow-3D, however, I'm not entirely sure if it is helpfull in my case, or even how it works.
Can someone please give me a help on this problem, especially considering that the grids have a big influence on the airflow, rendering their definition essential to a proper validation on this simulation.
Thanks in advance!
FUDM is offline   Reply With Quote
Old   July 15, 2016, 05:24
hanif pourshahbaz
hanif pourshahbaz is on a distinguished road
Originally Posted by FUDM View Post
Thanks in advance!
Do you still need a hand?
hanif pourshahbaz is offline   Reply With Quote
Old   October 19, 2016, 10:36
Fábio
Hello hanif pourshahbaz,
I am just now resuming my work on this subject. In fact, I had given up on the idea of using the conforming mesh option, since I was told that a simple baffle with a porosity corresponding to the grid's holes could be a close approximation to my problem.
However, I am still not sure what is the best way to deal with this problem. If you are still willing to give me a hand, I would be very thankful!
Best regards.
cell size ratio, conforming mesh, ventilation grids
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
