November 13, 2015, 15:13 |
Mass Density and floating objects
Ontario
Rep Power: 11 |
Hi I’m just starting to do some floating object study’s, I have a couple of questions.
The objects that I’m trying to float is made up of different densities. What is the best way to set them up for flow3d. I have two thoughts about how to set it up. 1. Assembly the component with subcomponents and specify each object's mass density separately and allow flow3d to calculate the moment of inertia tensor 2. Make the component one object and apply the moment of inertia tensor manually. Question: is there a method of converting the information from solidworks to work in flow3d? Thank you for your time Cheers Ian Dunlop |
April 4, 2016, 17:10 |
Ontario
Rep Power: 11 |
thanks for the advise
Cheers Ian |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 10:21 |
Floating point exceptions with own modified k-omega SST with Reboud's correction | A_Pete | OpenFOAM Programming & Development | 3 | October 18, 2016 02:45 |
Is OpenFOAM capable to simulate a floating object with variable density? | Idosar | OpenFOAM | 0 | September 29, 2015 17:13 |
Instability introduced by using mutRoughWallFunctions? | AlexC | OpenFOAM Running, Solving & CFD | 1 | March 18, 2014 15:14 |
Floating error | Arconis | STAR-CCM+ | 6 | February 18, 2012 11:08 |
