Home > Forums > Software User Forums > FLOW-3D
Flow 3D Cast Exporting Output as Text File
Old   October 30, 2015, 12:51
Default Flow 3D Cast Exporting Output as Text File
Shantanu
shantanu1 is on a distinguished road
Hello All,
I am new user of Flow 3D Cast. I need to run Flow 3D Cast by varying input parameters and study the impact of this variation on the output parameters. Since this is to be done several number of times, I want to automate this process. I could figure out the way to run series of simulations by writing the ‘prepin’ and ‘workspace’ files and opening them in Flow 3D Cast. But the ‘flsgrf’ file which contains the results is in binary format and hence I am not able to extract meaningful data out of it. I wanted to know if I can set some flags in the ‘prepin’ file to get the required variables as output in ASCII format so that I can process those variables further outside Flow 3D Cast. For example, I need velocity values at every node in the mesh as a function of time. I do not want to use the Flowsight GUI to do this because I want to generate output files for more than 50 simulations done sequentially. Hence doing it manually through GUI is not feasible.
I would be grateful if anyone has any idea about how to do this automatically. Thank You.
Regards:
Shantanu
shantanu1 is offline   Reply With Quote
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
