Home > Forums > Software User Forums > FLOW-3D
2D Fluid Force
Old   October 30, 2015, 09:05
Default 2D Fluid Force
jiko
jiko is on a distinguished road
I have a 2D simulation setup. z-direction is one cell wide and gravity is acting in -ve z-direction. Flow is coming from X-min and outflow boundary is at X-max.
Does the fluid force in this case represent Force per unit length or is it Force per length of the z-axis?
The 2nd query: I have prescribed a known hydrostatic pressure at the y boundaries (static pressure) in order to aid the simulation pressure convergence. Is this correct?
Due to 2D cross-sectional domain being at certain water depth the hydrostatic pressure is imposed on y.
Any comment will be greatly appreciated.
Regards
jiko is offline   Reply With Quote
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
Multiphase heat transfer pkladisios CFX 8 June 7, 2016 02:41
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Fluid force in UDF linh nguyen Fluent UDF and Scheme Programming 0 May 21, 2014 09:02
