Home > Forums > Software User Forums > FLOW-3D
Taking the top surface of the fluid
Old   September 9, 2015, 06:32
Default Taking the top surface of the fluid
Ezgi Bdk
ezgibdk is on a distinguished road
Hi to all
I have a problem that I cannot solve anyway. I did an analysis of a 180 degrees meander. From this analysis, I want to take the top surface of the fluid so that I can open it in Pointwise. Is there any way to solve this? All I want is extracting x,y,z coordinates.
Thank you for your kind attention. Have a good day
ezgibdk is offline   Reply With Quote
Old   September 22, 2015, 00:27
Default Probing the Free surface elevation
Taimoor Ahmad
Taimoor Ahmad is on a distinguished road
You can do this by "Probing". Go to 'Probing' in Analysis tab and select Probe. There you can select different parameters to probe. Select "Free surface Elevation". Good Luck
Taimoor Ahmad is offline   Reply With Quote
Old   October 7, 2015, 04:54
Ezgi Bdk
Thank you for your replying Taimoor Ahmad
It could be work, but I found a solution in Tecplot later. Thanks anyway,have a good day
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
interFoam-losing fluid in free surface simulating amin66 OpenFOAM 39 September 23, 2019 03:53
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
[ANSYS Meshing] How to include an internal surface in fluid vol jwillie2000 ANSYS Meshing & Geometry 0 May 4, 2012 12:10
[Polyflow] interface between fluid and surface tension in 2D Airone FLUENT 1 June 18, 2010 15:37
