Home > Forums > Software User Forums > FLOW-3D
Can't obtain 3D results and text output
Old   June 2, 2015, 07:42
Default Can't obtain 3D results and text output
Fábio
FUDM is on a distinguished road
Hi!
I'm running an airflow simulation in Flow-3D v.11. When I try to analyze the results, I obtain very decent 2-D results, however, the 3-D results are always empty (every parameter is equal to zero). When I try a text output, for instance to see velocity and pressure values, they are also all equal to zero.
I don't understand this, considering the good 2-D results.
Does anyone know why this could happen?
Thanks in advance!
FUDM is offline   Reply With Quote
2-d, 3-d, text output
Exporting some results data at text file format Asghari_M OpenFOAM Programming & Development 4 May 6, 2015 17:46
saving calculated results in text file houss OpenFOAM Running, Solving & CFD 0 August 4, 2014 10:52
how to retrieve output to a text file!! Ananthakrishnan Fluent UDF and Scheme Programming 4 May 3, 2013 12:02
Extracting results file to a text file ealatawi CFX 3 December 17, 2009 05:34
Export CFD Solver results to text file format Maik Main CFD Forum 2 May 23, 2008 02:34
