Home > Forums > Software User Forums > FLOW-3D
Baffles in Flow-3D
Old   May 15, 2015, 12:20
Default Baffles in Flow-3D
SvenW is on a distinguished road
Dear FLOW-3D (V11) users and experts,
I have a question about how to use baffles at the in- and outlet of an irregular formed tube.
The problem: water should only flows from top to down inside the tube. Therefore I set baffles at the top (z max) and bottom (z min) of the cartesian mesh block: a third baffle (type hole) was created with a STL file (eq. inside of the tube).
With exact this STL file the fluid region is defined as an initial condition.
The result: FAVOR shows all the time a complete flooded mesh block as fluid surface. I know, there is an other method to get the inside flow by creating a solid block and subtract the STL file with boolean operation, but this I didn't want.
Any help is highly appreciated. Thank you in advance.
SvenW is offline   Reply With Quote
baffles, flow-3d, v11
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
thin baffles surrounded by flow region ACmate STAR-CCM+ 3 July 16, 2012 20:43
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 07:12
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
