Nima
Rep Power: 12 ![]() |
Hi every body.The model introduces a bed scour caused by a turbulent jet, but the "packed sediment height net change" shows positive values- as i know it should be negative- although the scoure hole has been generated.I would be appreciated if someone gives me the solution.is it becuz of the coordinate or sth else.[ATTACH]flow packed.jpg[/ATTACH]
The pictures are attached. |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 07:27 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
