How to model two phase high jet speed in converging - diverging nozzle? |
March 19, 2015, 12:42 |
Shailesh Konda
Rep Power: 13 |
I am trying to model liquid atomization and primary breakup in a converging- diverging nozzle using FLOW 3D. The geometry is attached below. It is a cross flow of water on a high speed jet combustion vapor. To start with am trying to model a cold flow simulation of water- air, which would create a spray at the exit. There are two parts for it, first is the primary atomization of liquid to vapor and then the formation of spray. I am more interested in the first part of the process. How should i go about modeling this in FLOW3d? Is it possible to model in Flow 3D? In my initial research, i can see that Flow 3D can be used for stratified and slug flow sort of fluid models.
Simulation of Axisymmetric Free Jet using LRR Reynolds Stress Model | skyinventorbt | OpenFOAM | 1 | January 2, 2022 18:42 |
How to access only one phase in multiphase model by UDF | wersoe | Fluent UDF and Scheme Programming | 1 | January 4, 2017 08:11 |
C-D nozzle supersonic jet boundary | Gland | FLUENT | 4 | May 24, 2012 01:25 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 26, 2009 00:27 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 02:45 |
