March 2, 2015, 12:01 |
Pressure Boundary Conditions
Fábio
Rep Power: 11 |
Hi!
I'm trying to simulate a room (4 walls) at a specific air pressure. I thought of defining the "specified pressure" boundary condition at each surface, indicating the pressure value. However, my question is what would be the pressure in the room's void space (within the boundaries)? Thanks for the help! |
March 21, 2015, 16:10 |
Jeff Burnham
Rep Power: 17 |
The pressure boundary condition is set at the center of the first boundary condition "ghost" cell which is outside of the domain. You can find the center of this cell in Diagnostics > Preprocessor Summary > Search for "mesh generated in z", and look at the zk values for n = 2 and nmax - 1.
Once you know the locations Zmax and Zmin of the boundary pressures on z-max and z-min boundaries, set the pressures Pzmax and Pzmin = Pzmax + RHO*h*g, where h = Zmax - Zmin. Then set the initial conditions > global > initial pressure > hydrostatic. Now you will have a hydrostatic pressure distribution in the domain that will be maintained throughout the simulation unless the fluid flow disturbs it. If you make a mistake you will see big velocity drafts of many meters per second going out this sides or bottom of the domain. |
March 21, 2015, 18:22 |
Fábio
Rep Power: 11 |
Thank you very much for the help! I'll see what I can do!
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 06:58 |
Help with pressure boundary conditions | Stephen Waite | FLUENT | 0 | September 12, 2013 06:45 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 18:15 |
