March 2, 2015, 08:59 |
covergence's problem with gravity
flavia turi
Goodmorning.
I'm trying to simulate a very very simple case: a verticale pipe with one enter and one exit, with a laminar flow. The fluid is liquid water, in standard condition that comes from the down to the bottom. I choosed, in the boundary condition's box, for: 1 enter, a velocity inlet of 0.01237 m/s 2 exit, a pressure outlet, constant normal to boundary, of 130000Pa. In general's box i checked gravity with an acceleration magnitude of -9.81m/sē (on the z axis). In operating condition i choosed an operating pressure of 101325 Pa and i checked specified operating density with a value of 0. I choosed first order momentum end i made a standard initialization with the enter. But i have a big value of residuals (in the orders of 1e-1). If i don't check the specified operating density, residuals decreases. I don't understand the reason; Thank you in advanced for your answer |
March 21, 2015, 16:06 |
Jeff Burnham
Rep Power: 17 |
Compare the residuals to the convergence criteria epsi.
If resid < epsi, then the pressure solver has converged correctly. If you want to use a tighter convergence tolerance, use Model Setup > Numerics > Pressure Solver Options > Converge Controls > Convergence Crtieria Multiplier epsadj = 0.001 or 1e-6. The default is 1, and the number multiplies the dynamically-selected convergence criteria by that value. If epsi > resid, then the pressure solution is not converging. Check: do you have fluid initialized in the domain? Do you have mesh smalls small enough that the pipe open area is resolved by at least 4 cells (and for an accurate answer, 10 - 20)? Do you have any other physics active besides the two or three you need: Gravity, Viscous Flow, and maybe Turbulence? I don't understand what you mean about un-selecting 'specified operating density'. FLOW-3D requires fluid density RHOF to run. |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
Two Phase Darcy flow with gravity -> problem | Cyp | OpenFOAM Programming & Development | 0 | November 17, 2010 08:58 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
gravity problem. | vidhuresh | FLUENT | 6 | October 31, 2005 01:59 |
