January 18, 2015, 10:54 |
export to flow 3d
Nima
Rep Power: 12 |
Hi dear members;
i did my model in Solid work with meter as length unit(for example 1 meter).but when exporting to (.stl), flow 3d shows the same length(1 m) as (1000 probably mm).what would be the problem? thanx again. |
January 19, 2015, 19:26 |
Jeff Burnham
Rep Power: 17 |
SolidWorks is displaying in m but exporting in mm. You can either change the setting in SolidWorks, or import the mm-based .stl into FLOW-3D and set Meshing & Geometry tab > Geometry > Component X > Subcomponents > Subcomponent X > Transformations > Magnifications > Global = 0.001. This will rescale the part back to meters.
March 21, 2015, 14:52 |
Mojtaba Ans
Rep Power: 11 |
before you export your model in Solid works, you can set your length unit in "Save As" Window, Option.
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 06:58 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 09:33 |
export only a part of the flow | julien | Siemens | 1 | March 7, 2009 12:32 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 08:40 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 06:57 |
