Home > Forums > Software User Forums > FLOW-3D
water spray small droplets
Old   December 30, 2014, 06:09
Smile water spray small droplets
Paulius
PauliusRap is on a distinguished road
Dear forum members,
I have a simulation with air and water interaction. during this simulation a water spray forms (tiny splashes of water and air) that seem to cause simulation to stop (iteration did not converge). I am using a quite a dense mesh and further reducing the size of cells could become a bit to difficult to my machine. Maybe someone could suggest a way around the problem with splashing water?
Best regards,
Paulius
PauliusRap is offline   Reply With Quote
Old   January 3, 2015, 21:08
Jeff Burnham
JBurnham is on a distinguished road
First try making your initial conditions match your boundary conditions so that fluid isn't splashing at the beginning. If you already tried that, then try Model Setup > Numerics tab > VOF Methods > Advanced Options > Fluid Fraction Cleanup (FCLEAN) = 0.15. That will delete any fluid regions where all connected cells with fluid have < 15% fluid in them. In other words, it will delete droplets.
JBurnham is offline   Reply With Quote
spray modeling, water and air
help - spray droplets Diegoesteban FLUENT 0 August 4, 2013 21:34
Coupled DPM water spray inside enclosed volume of air dan86 FLUENT 0 July 19, 2013 12:23
Mass Flow rate in spray water modeling Behnam Ghadimi FLUENT 0 June 8, 2013 17:05
water jet spray structure FLUENT 0 June 23, 2009 02:48
Simulating Water Splash Using a Particle System Zi-Wei Chiou Main CFD Forum 0 March 4, 2002 07:33
