December 15, 2014, 04:23 |
Surface Roughness Problem
RoyDaniel
Rep Power: 12 |
Dear All Flow 3D Modellers ,
Now I am creating models of simple open Channel which its length is 200 m with various Surface Roughness. To input Surface roughness, I just used the equation which is mentioned in the users manual "FLOW-3D Documentation, Release 10.1.0" page 409. the input symbol is k which is derived from manning's , Rh (Hydraulic adius) and Dh (Hydraulic Diameter). As my mannings are 0.035 and 0.05 and my channel size is 25.5 m width and 10 m depth, hence it yields k = 0.5886 ( for n = 0.035) and k=2.602 ( for n = 0.05). Then , I have make running for those two value of k ( surface roughness), but unfortunately both results show the same value of water depth ( please see figures on attachment files), according to my knowledge in open channel they should have different water depth result. Could anyone help me to give some comment that I may have made some mistakes in this model? Thank you so much Best Regards, Roy |
December 15, 2014, 07:19 |
Serhan Aldogan
Dear Roy,
Is it possible that something with physics is wrong? |
December 15, 2014, 09:29 |
Dear Sehran
RoyDaniel
Rep Power: 12 |
Dear Sehran,
I think you're correct, it may have mistake with Viscosity and turbulence. Let me check first , then I will let you know. Thank you so much Sehran .. Cheers Roy, |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
free surface problem with capillary effect | rabbitmelon | CFX | 25 | August 16, 2013 04:05 |
Problem in specifying the boundary condition for tank's surface which is on fire | BHE | FLUENT | 1 | March 22, 2013 00:02 |
open channel problem (free surface) | Andy Chen | FLUENT | 4 | July 10, 2009 02:20 |
