November 20, 2014, 06:06 |
VOF case
kedar
Rep Power: 15 |
Hi
I am new user of FLOW-3D. I am simulating a bottle which is filling by liquid, it is a multiphase (liquid+air)case. For this I am using VOF model. simulation part has done. Now I am analyzing results, I want to estimate both liquid & air volume inside the bottle for different height. In Analyze Tab I did not get any available variable which will help me to find those two volume values, even I have analyzed hd3out. file also. Any one knows how to sort out this issue? Thanks in advance.. |
November 20, 2014, 11:14 |
Akshay Kumar
Rep Power: 16 |
Hey
At the end of the simulation, flow3D prints out the volumes of the phases. You can check this in the hd3out file. Another method is that you can use sampling volume to measure the quantities. Cheers! |
November 28, 2014, 01:32 |
kedar
Rep Power: 15 |
Thanks Akshay.....
implementation of mapFields into parallel transient case | simpomann | OpenFOAM Pre-Processing | 4 | August 2, 2016 05:41 |
icoFsiFoam case needed | vivekcfd | OpenFOAM | 1 | May 6, 2009 14:41 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 09:07 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
ATTENTION!! Validty of Fluent's VOF?? | ozgur | FLUENT | 1 | February 18, 2004 12:59 |
