October 22, 2014, 22:51 |
Create simple open channel flow
RoyDaniel
Rep Power: 12 |
Dear All Friends,
My name is Roy Daniel, I am a grad student, and now my thesis advisor want mo to create a simple 1D open channel flow by using Flow 3D. Is there any body could explain me from where I should start , for example where can I make cross section data such as Trapezoidal shape, rectangular etc , and then roughness coefficient such "chezy" roughness and also boundary condition.. Thank you all for your time and share My best regards, Roy Daniel |
October 24, 2014, 07:01 |
Chris
Rep Power: 12 |
Hey and welcome,
from my point of view it is advisable to study the according chapters of the manual and also have a look at the examples given in the software. All the best, Chris Last edited by chripasch; October 24, 2014 at 08:50. |
October 24, 2014, 08:35 |
RoyDaniel
Rep Power: 12 |
Hi Chris
Thank you so much for you advise. You're right I'll have a look to manual and related chapter for my modeling, since I know the Flow 3D is a very wide & complex software of hydraulic modeling so I have to see which is related to my research. Thanks again Kindly cheers Roy Daniel |
open channel flow |
simple open channel flow, the inlet and outlet are periodic | Sniper | OpenFOAM Pre-Processing | 31 | December 28, 2023 03:12 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 10:03 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 08:06 |
open channel flow boundary conditions | yan | FLUENT | 0 | July 5, 2005 00:36 |
SIMPLE Scheme for open channel flow | ao | Main CFD Forum | 0 | April 6, 2004 17:21 |
