October 8, 2014, 09:07 |
Coordinate offset when importing stl file
Chris
Rep Power: 12 |
Hello all together.
I would appreciate if somone could help me with the following problem: I am drawing a geometry with CAD (AutoCAD Civil 2D 2013) ansd am exporting it as stl-file to import it to FLOW-3D. With version 9, there was no problem. Since version 10, I got an offset in the point of origin. For example, in CAD the point is (x,y,z) = (0,0,0). Importing it to FLOW-3D, it is moved very little in the range of e-07. With version 10, I just used the option of translating the component in the other direction with the same value and obtained a zero. That does not work with version 11. Using the "method" described above, the offset then changes prefix and reaches an even smaller value. I attached a screenshot where you can ee the offsets in x-, y- and z-direction. It is not geometry-dependent, I have the problem with all stl-files I create / use. Thank you very much for your help. |
October 14, 2014, 19:34 |
Jeff Burnham
Rep Power: 17 |
The offsets are numerical and are related to significant number of digits in the computer. They may be appearing just in the user interface, and not in the solver, and if they appear in both the offset will be different in the user interface vs. the solver.
Therefore you don't want to try to fix the offset reported when it's E-7 or less. If that amount of difference matters, use a different unit system. Make sure you're using binary-format .stl files. Not only are they smaller, but they have a set number of significant digits for each coordinate, so they are less likely to show the offset. ASCII-format .stl files can have too many digits in them and sometimes caused significant offset effects prior to FLOW-3D v11. |
October 17, 2014, 09:46 |
Chris
Rep Power: 12 |
Hello Jeff
Thank you for your helpful reply. True, tchnically the minimal offset is not a problem. But I wasn't sure if it could lead to problems for the solver if there is a minimal gap. Szenario: I want to place the Xmin-BC to x = 0 (which should coincide with x = 0 of the geometry). If the software "thinks" the geometry starts at x = 0.00001 for example, there is a small gap which could possibly (!) cause problems. Anyhow, I tested the export as binary- ans ASCII-STL file. They both lead to the same offsets. From my point of view, the question can be "closed". Thanks again. |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 07:29 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 14:14 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 06:18 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
