Home > Forums > Software User Forums > FLOW-3D
problem to simulate Linear Wave
Old   October 7, 2014, 22:59
Red face problem to simulate Linear Wave
azlan musa
azlan is on a distinguished road
Hi
I am beginner in FLOW 3D,and I wish to simulate linear waves in a tank.
Unfortunately,I found the free surface elevation is not linear as a theory. If I choose "outflow" as the boundary condition,the free surface elevation will reduce in a steady rate. Same thing happened when I change the boundary condition into "wall" or "Symmetry", the free surface elevation is still not linear.
So I really wish to know why does it happen and how to solve this problem, can any experienced user can help me out?
Thanks.
Azlan
azlan is offline   Reply With Quote
Old   October 9, 2014, 02:52
Allenlin is on a distinguished road
Hi, azlan
The simple way is extend you computing domain, to reduce the outflow boundary influence. If the phenomenon that you focus is not include the downstream side.
Allenlin is offline   Reply With Quote
Old   October 12, 2014, 21:37
azlan musa
tq allenlin..
i already extend the domain.. unfortunately, the wave is still nonlinear.. did you have any example of linear wave propagation using flow 3d?
hope you can help me..
Thank you very much..
Old   October 12, 2014, 22:23
To azlan
From your post, the free surface elevation will reduce. I assume that the simulated wave shape is similar with theory. It looks like the numerical diffusion error is not under control. Can you try to increasing your mesh resolution ?
Old   October 13, 2014, 09:15
Default Similar Problem but simulating using a piston type wavemakemaker
Ricky Dada is on a distinguished road
I'm trying to simulate actions of a piston type wavemaker in a numerical wavetank using GMO for prescribed movement of the piston. The fluid is inviscid & incompressible with a free surface. The numerical domain is 2D, with x as lengthwise axis & z as axis along vertical direction. The start of the wave tank has the piston position at its mouth. The bottom of the tank is closed while the top is open to atmosphere. Boundary conditions are as follows
Xmin-Wall
XMax- Outflow
Zmin-Symmetry
Zmax- specified pressure(Stagnation pressure is turned on with fluid fraction pecified as 0. Pressure specified is atmospheric).
Intial conditions:
Total depth of tank is 0.8 m. Water filled upto water depth i.e. 0.6 m.Void pressure is atmospheric.
Prescribed Conditions on Piston GMO:
It is desired to impose a sinusoidal motion of period 1 sec on the piston. However in order to start motion in a smooth manner, i've imposed velocity for first 4 secs using the table format. Later i use a restart simulation to simulate for period between 4-30 secs using the results of previous simulation as described before. Therein i use inbuilt sinusoidal prescribed motions on the piston with appropriately calculated initial phase.
My Problem is first, since flow-3d uses immersed boundary method, is specifying Xmin as wall type boundary right?
Secondly, all wave kinematics calculated analytically do not match with flow 3d calculations. I've seen a Phd thesis from one Eoghan Maguire who has reported good results for simulation upto 20 secs. However i'm unable replicate his results. Any help??
Ricky Dada is offline   Reply With Quote
Old   October 13, 2014, 09:50
Xmin-Wall
XMax- Outflow
Zmin-Symmetry
Intial conditions:
A turbulent test case for rhoCentralFoam immortality OpenFOAM Running, Solving & CFD 13 April 20, 2014 07:32
Use "bounded" in scheme or not to use? immortality OpenFOAM Pre-Processing 0 June 11, 2013 17:20
convergence problem in using incompressible transient solvers. Geon-Hong OpenFOAM Running, Solving & CFD 13 November 24, 2011 06:48
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 02:23
simulate propagating wave Gian, S. Main CFD Forum 0 October 27, 2006 04:11
