Home > Forums > Software User Forums > FLOW-3D
Air-lift model with hot gases and water. Time step problem.
Old   August 4, 2014, 05:47
Unhappy Air-lift model with hot gases and water. Time step problem.
Paulius
PauliusRap is on a distinguished road
Dear Flow3D CFD community ,
I have some trouble with a model in FLow 3D and I was hoping to get some suggestions if anyone could help me I would really appreciate it . The model that I am running is a air-lift reactor. It is basically a rectangle vertical tube that is filled with water. At the bottom of the tube is a fluid source. The fluid source supplies hot air (600K) that bubbles upwards to the external outflow from the tube. Addition of water is realised by using a pressure boundary with fluid elevation. The model has to evaluate phase change in the water. The model seems to be working (I have used a model with phase change from the examples given by flow 3D as a base). However the time step decreases significantly after 0.6 sec of simulation and the model crashes. I do get errors „Possible two-fluid velocity slip problem. Density ratio less than 10 to 1 may not be suitable for slip treatment.“ And if I turn of the slip option it says to turn velocity slip on.
PauliusRap is offline   Reply With Quote
air bubble, phase change, two fluids
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 15:27
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
FSI: Pressure and Normal Force don't match with expected values Geraud CFX 6 August 21, 2012 16:34
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
error using combination of step function xujjun CFX 1 January 15, 2008 17:46
