July 29, 2014, 05:10 |
Drag Force
Rep Power: 12 |
Is it possible to obtaion to drag force on something like "spur dike" from FLOW3D directly or indirectly?
July 29, 2014, 17:32 |
Jeff Burnham
Rep Power: 17 |
Yes. Make the spur dike a separate component from the rest of the model. Under component properties > output turn on pressure and shear force outputs, and wetted area output. Then run. The output, integrated over the surface of the component, will be in Anaylze > Probe > General History data. There's a button on that tab to select graphical or text output.
August 3, 2014, 14:20 |
Rep Power: 12 |
Thank you very much
But could you explain more? How we can exteract drag force efter that? |
April 19, 2017, 13:11 |
#4 | |
Rep Power: 9 |
I need Drift Force on the Object. more Specific, Second order Forces. is there any way to extract this Force directly? |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 12:12 |
FLUENT: how to record drag force at every time step? | qiulan | FLUENT | 4 | March 20, 2017 22:22 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
Force vectors for drag during sweeping motion | aamer | FLUENT | 0 | April 18, 2011 09:17 |
formula used for drag force? | kamma | Main CFD Forum | 0 | April 2, 2010 11:21 |
