Home > Forums > Software User Forums > FLOW-3D
Big problem in Friction test
Old   July 4, 2014, 15:56
Default Big problem in Friction test
Saeid Ahmadvand
Saeid is on a distinguished road
Hello to all,
I run a lot of models about simple friction test.
I have 1 cube in my model with this informationall SI unit)
dimensions: 0.5*0.5*0.5
mass density: 2000
collision properties: Coefficient of friction=0.5 & Coefficient of restitution=0.9.
Type of moving object: Coupled Motion(all velocity = 0 , z displacement in negative direction = 0 , 6 Degree of freedom)
and behind of this cube, there is a fluid regime with 6 m length and 0.5 m height(water) (initial velocity=0 and pressure distribution is Hydro-static).
just this.
after I run the model, the cube start to move!!! this is my problem!!
as I know about equilibrium equation for this simple test, the cube must not move, but it move.
please help me if possible.
Saeid is offline   Reply With Quote
Old   July 6, 2014, 04:52
Saeid Ahmadvand
No one can help me?
Problem with grid dependency test alexrab89 Siemens 0 June 19, 2013 05:36
Problem with p_rgh with interDyMFoam in a ship roll decay test karmo OpenFOAM Running, Solving & CFD 1 August 23, 2012 18:07
the big problem about flow3dMP bojiezhang FLOW-3D 1 April 21, 2010 20:12
I have a big problem of convergence, please help ! amel FLUENT 3 February 15, 2007 16:32
setup vof test problem Fang Jin FLUENT 1 June 14, 2005 09:27
