June 24, 2014, 13:01 |
Rotate mesh
Rep Power: 12 |
Hi everyone! I am new to Flow3D and need some help from you guys. I have a component that I just rotated and I want my cylindrical mesh to follow. How do I rotate my mesh?
July 5, 2014, 21:50 |
Jeff Burnham
Rep Power: 17 |
Sorry, you can't rotate the cylindrical mesh. Z is always the axis direction of the cylinder. You can set gravity in a different direction, though: use the gravity components under Non-Inertial Frame option to set gravity in a Cartesian direction other than z (if you set it in x without the non-inertial frame, gravity points in all directions away from r = 0, right? So you must use non-inertial so gravity points only in one Cartesian x direction, not r, when you use cylindrical coordinates. Rotate your frame of reference instead.
July 9, 2014, 07:08 |
Rep Power: 12 |
Thank you JBurnham. Problem solved!
June 27, 2022, 08:41 |
AMD
Rep Power: 4 |
Dear friend.
Have you solved the problem? I don't hope to transform the model or component. Is there any method to transform the direction of the cylinderical mesh. How to rotate or transform the mesh? Thank you very much! |
mesh, rotate |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
