solver stops when erosion should be starting? |
June 2, 2014, 04:50 |
Pieter-Jan
Rep Power: 12 |
Hey!
So, I'm making a model in Flow 3D, about the final stages of placing a skirted GBS on the seafloor (1.5m above seabed till 0m above seabed). The z=0 line is at the surface of the sand. The BGS has a downward velocity of 0.2 m/s. The problem I have, is that the solver stops when the skirt tip touches the seabed. Normally erosion should start here (or some seconds before the skirt hitting the seabed) because there's still water inside the skirt before the GBS reaches the sea floor. Here's what I did so far: - I have the scour model activated, with a set critical shields and 1 particle diameter - I also activated viscosity and turbulence RNG model, with a constant mixing length of 0.0001. - My soil is set to packed sediment. |
different results between serial solver and parallel solver | wlt_1985 | FLUENT | 11 | October 12, 2018 09:23 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 10:52 |
Using a user-defined solver in OF | ozzythewise | OpenFOAM Running, Solving & CFD | 3 | February 8, 2011 16:28 |
Getting too many iterations by velocity solving (aborting). Changing U - Solver? | suitup | OpenFOAM Running, Solving & CFD | 0 | January 20, 2010 08:45 |
Error during Solver | cfd guy | CFX | 4 | May 8, 2001 07:04 |
