Home > Forums > Software User Forums > FLOW-3D
Rotational axis for hydrodynamic screw
Old   June 2, 2014, 04:29
Default Rotational axis for hydrodynamic screw
SirLankyIII is on a distinguished road
I've been working on a hydrodynamic screw simulation and I'm having trouble fixing the axis of rotation. I've been able to limit the translation in the motion controls, but when the fluid strikes the screw and starts turning it also bounces it around rather often through other geometry even with the collision model on.
The screw has an angle of 30 degrees if that helps at all, motion is coupled, translation allowance is set to 0 in all directions.
If anyone could shed any light on how to fix the rotational axis, I'd greatly appreciate it.
SirLankyIII is offline   Reply With Quote
Axis treatment in axisymmetrical problem Jakob1 OpenFOAM Pre-Processing 2 August 25, 2014 04:09
[ICEM] Rotational periodicy setup Procyon ANSYS Meshing & Geometry 0 April 30, 2011 08:55
Writing Moment coefficient for different walls at different rotational axis harishameed33 Main CFD Forum 0 April 27, 2010 13:17
Defining a moving rotational axis! Samuel CFX 3 September 12, 2007 11:00
Specifiying rotational axis' - a bit stuck Dave FLUENT 1 August 31, 2007 06:18
