Home > Forums > Software User Forums > FLOW-3D
Sedimentation Tank Baffle
Old   March 3, 2014, 02:25
Default Sedimentation Tank Baffle
Baharan Molaie
Bmolaie is on a distinguished road
I'm trying to model a rectangular sedimentation tank, but baffles seems to have no effect on the model, I tried to use the baffle option and also I tried to define it as a solid object... should I consider any specific considerations?!
Bmolaie is offline   Reply With Quote
Old   March 12, 2014, 22:08
Jeff Burnham
JBurnham is on a distinguished road
The mosikely reason the baffles aren't affecting the flow is that they may not be defined correctly. Baffles must be defined with one (1) "definition" (X-plane coordinate, for example), and then limiters can be added to cut the baffle down to the correct size (y-min, y-max, z-min, z-max, for example, if the definition is an x-coordinate). If you rotate the baffle, it is rotated around the origin, so rotated baffles are easiest to define about the origin and then translate them to their final location. Preprocess the simulation before you run it: view the output to check if the baffles are correctly defined and placed.
JBurnham is offline   Reply With Quote
Old   March 16, 2014, 07:28
Baharan Molaie
thanks
I also have some confusion about the inflow and outflow... I did a laminar model but the inlet and outlet volume rate are not the same... is there any option in the software that I could determine that?! (I need height of the water to stay constant but I could only assign the height in initial conditions)
Old   March 19, 2014, 22:26
Jeff Burnham
If you don't want to predict the shape of the free surface, then set "no sharp interface" option. All cells will be filled with fluid. Put the z-max boundary condition at the fluid "surface" and set it to Symmetry type, or put a solid component over the free surface and set the friction coefficient = 0 for free-slip.
If inflow still does not equal outflow, check that you are not losing fluid through cracks in your geometry, that the mesh cells are as close to cubes as possible, that the boundary conditions are correct, and that the simulation runs long enough to reach steady state.
Good luck.
baffle, sedimentation tank
Need Help! High pressure Gas discharge from tank to tank through a pipe superarthur86 FLUENT 2 June 16, 2017 11:22
Mixture and Decay of a tracer in a Water Tank Jeffrey1992 CFX 2 July 27, 2012 14:31
Initial conditions in sedimentation tank CFD_UJI CFX 0 December 14, 2011 14:11
Blow Tank Simulation ... Need Help! treyevans CFX 1 February 20, 2010 01:42
Sedimentation Tank Petridis CFX 0 May 14, 2005 06:23
