November 17, 2013, 08:09 |
STL problems
ouni firas
Rep Power: 13 |
I'm trying to build a STL file from BLOC NOTE; assets after import STL file for FLOW 3D, it was put in the slot, and the figure is correct. but when I run the simulation an error message shows:
''' number of triangles processed successfully: 0 the last line read from input file: facet normal 0.0000 0.2000 0.0000 error occurred when reading line: 0.0000 0.2000 0.0000 level 0 error in subroutine rdstl: normal vector dataset error level 1 error in subroutine cadstl: error while reading stl file ''' |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 13:13 |
[ICEM] STL file to IGES | rana41671 | ANSYS Meshing & Geometry | 0 | September 21, 2010 17:27 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
STL File - Mesh Surface Problems | Harmeet | CFX | 3 | June 10, 2004 19:19 |
Some problems with Star CD | Micha | Siemens | 0 | August 6, 2003 14:55 |
