September 26, 2013, 00:15 |
Heat Pipe Calculation
Dr. Li
I built a one loop heat pipe with some water in it.
The calculation is terminated with the error "excessive pressure iteration failures -- calculation terminated" It seems that the domain meshing(3D) and the surface contact angel influence the calculation. Just frustrated after a lot of trials- all failed Is there anyone who do the simulation of 2-phase flow with heat transfer and phase change? |
Heat pipe Simulation | Heat Pipe | FLUENT | 37 | July 15, 2022 06:48 |
Pipe flow heat transfer | feedq | FLUENT | 10 | November 26, 2014 09:23 |
Heat Flux calculation inside domain | shikamaru | Fluent UDF and Scheme Programming | 0 | November 14, 2012 10:51 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
heat transfer through fluids in a pipe in pipe | madasu | FLUENT | 1 | July 15, 2002 11:14 |
