August 29, 2013, 03:09 |
Scour around vertical cylinder
bird
Rep Power: 14 |
Dear all,
Hi, I am simulating scour around a vertical cyliner subjected to steady current. Here is the parameters: 1. The mean velocity of the current is 44.1cm/s, and the inlet boundary is "Grid Overlay", which means the current is developed. 2. The diameter of the cylinder is 10cm, and the height of it is 25cm. 3. Before simulating scour, simulation of flow pattern around the cylinder without sediment is taken, vortexes can be found and the size of the grid is ok. 4. Other parameters of the sediment are shown in the attachment. The problem is: The process of scour is quite slow that no apparent scour pattern can be found around the vertical cylinder. In other words, the cylinder seems to contribute little to the process of the sediment scour, why? |
August 29, 2013, 03:11 |
bird
Rep Power: 14 |
In addition, long long time is gone but the scour pattern is still not apparent.
September 10, 2013, 17:06 |
mahdi
Rep Power: 13 |
September 17, 2013, 21:56 |
bird
Rep Power: 14 |
The result is not good.
September 18, 2013, 05:11 |
mahdi
Rep Power: 13 |
send me your prepin file.
December 25, 2013, 03:28 |
Rep Power: 13 |
Free convection from vertical cylinder | Mariusz | FLUENT | 1 | February 2, 2017 14:36 |
The resistance force of flow around vertical cylinder is high | hpkidmr | FLOW-3D | 1 | August 28, 2013 00:46 |
Air natural convection inside a vertical cylinder | Pavolo | FLUENT | 3 | December 12, 2012 07:00 |
Vertical rotating cylinder | Abhishek V | FLUENT | 0 | December 16, 2006 17:20 |
flow below a vertical rotating cylinder | hani | Main CFD Forum | 1 | October 9, 2002 14:28 |
