Home > Forums > Software User Forums > FLOW-3D
Can Flow3D Simulate Heat Transfer from Air
Old   June 27, 2013, 13:46
Default Can Flow3D Simulate Heat Transfer from Air
Gang Chen
gangchen is on a distinguished road
Hello All,
I plan to simulate flow in a channel. Can Flow3D add heat transfer from the air temperature into the water temperature in the channel?
Thank you
gangchen is offline   Reply With Quote
Old   August 26, 2013, 11:17
Gang Chen
Then do you know how to do that?
Old   August 27, 2013, 15:39
Jeff Burnham
JBurnham is on a distinguished road
Physics = heat transfer (1st or 2nd order). No fluid-to-solid transfer is needed.
Set Fluids > thermal properties > "heat transfer to void type 1" (HFLV1) as the heat transfer coefficient between air and water.
Set void initial temperature = air temperature.
Set fluid initial temperature and boundary condition temperatures.
---that ought to do it. If it doesn't work, check the User Manual for the version you are using.
JBurnham is offline   Reply With Quote
Old   August 28, 2013, 11:22
Gang Chen
Thank you for your help. Can I ask you something? In the "heat transfer to void type 1", it means the heat transfer coefficient between air and water. But which number should we use, zero means no transfer? one means totally transfer?
Old   August 28, 2013, 12:01
Jeff Burnham
Units are [M T^-1 t^-3], so kg/K/s^3 in SI units. It's a heat transfer coefficient. All input variables are listed in the User Manual with their units. The chapter is called 'Input Variable Summary'.
Old   September 3, 2013, 18:18
Gang Chen
Thanks a lot.
[stressAnalysis] How to simulate thermal stress and heat transfer simultaneously using OF? masb OpenFOAM CC Toolkits for Fluid-Structure Interaction 18 July 20, 2015 23:24
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Simulate heat transfer of heat sink in a box... chien87 CFX 8 February 8, 2011 04:50
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
May fluent can simulate heat and mass transfer? yueroo FLUENT 3 April 24, 2001 12:19
