Home > Forums > Software User Forums > FLOW-3D
Cell definition diffrence
Old   June 10, 2013, 05:23
Default Cell definition diffrence
Zeregaber Moghes
Zerit is on a distinguished road
Hello All,
After running a simple model of water flow in an open canal. I get a part of the domain a little bit bigger than the neighbouring region. Eventhough the canal is straight I see a step in one specific area. Actually this area is defined by a smaller mesh size. Is there any difrence in the definition of a given cell in the preprocessing and post processing (cell defined by its center or by the edges)?
I appreciate your comments in advance.
Regards,
Zerit is offline   Reply With Quote
Old   June 12, 2013, 09:41
michael barkhudarov
MuxaB is on a distinguished road
Originally Posted by Zerit View Post
Hello All,
Regards,
No, it should be the same. Are you using multiple mesh blocks with different resolutions? If so, the pre-processor may show a small gap between them (or a change in cross-section), but it is most likely a plotting glitch rather than a real problems.
The pre-processor reports the differences in open areas at adjacent block boundaries. Look in prpout file, search for 'information' to see the actual numbers.
MuxaB is offline   Reply With Quote
Old   June 12, 2013, 17:48
Zeregaber Moghes
Thank you MuxaB.
Yes I am using multiple mesh blockes and I clearly understand your point. The trend of the selected paramter as well as the values don't get changed only the gap is the problem.
Old   July 13, 2013, 15:31
michael barkhudarov
Then it is most likely a plotting artifact.
Thank you MuxaB.
Old   July 14, 2013, 13:58
Zeregaber Moghes
it is basically a problem related with the nested mesh block definition. with better transition and mesh plane at the ends of the nested mesh block this problem was sorted out. In fact it helped me in detecting any problems in the mesh definition.
Old   July 14, 2013, 15:25
Zeregaber Moghes
i don't think it has anything to do with the plotting.
Old   July 14, 2013, 18:55
michael barkhudarov
Glad you figured it out. Nice work!
interFoam running blowing up sandy13 OpenFOAM Running, Solving & CFD 2 May 5, 2015 08:16
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Warning 097- AB Siemens 6 November 15, 2004 05:41
