June 8, 2013, 15:09 |
Particle Tracking
Zeregaber Moghes
Rep Power: 13 |
Hello All,
I am trying to track sediment movmemnt in Flow-3D so as to picture the incipient movement of the grains. I would be glad if you shove me some idea on how to do it. I mean aside to the checking the concentration difference. Thank you, |
June 12, 2013, 12:57 |
michael barkhudarov
Rep Power: 18 |
You could use mass particles - using the initial particle block or sources, - to track individual sediment grains. The particles would have to have the same properties - size and density, - as the sediment. However, particles do not interact with each other, unlike the real sediment particles.
June 12, 2013, 17:44 |
Zeregaber Moghes
Rep Power: 13 |
Hello MuxaB,
Thank you for your replay. I understand how the particles behave but I have no clue on how to activate it in the program and nothing is mentioned in the user manual/ Flow-3D documentation. Would you be kind enough to shove me some ideas on how to do it in F-3D. |
June 25, 2013, 03:18 |
Rep Power: 13 |
hi
it is very easy, go to particle in physics, choose block, define the location of your block, choose diameter and number of particle then ok. choose rho and other properties then run your case. i hope it helps u |
July 13, 2013, 15:29 |
michael barkhudarov
Rep Power: 18 |
July 14, 2013, 13:54 |
Zeregaber Moghes
Rep Power: 13 |
Right I have activated it and thank you gents.
It is funny though to find that the particles are behaving differently than the packed sediments. The packed sediment deposition and scouring is variable with respect to time & space clearly depicting the stochastic behavior. However with the mass particles, limited number move in a very short period of time and nothing is observed after that. So is it possible that the mass particles are behaving differently? |
July 14, 2013, 18:57 |
#7 | |
michael barkhudarov
Rep Power: 18 |
It is certainly possible. Mass particles do not get 'packed' like sediment does. They move according to the force balance - pressure, gravity, drag from fluid.
July 14, 2013, 19:37 |
Zeregaber Moghes
Rep Power: 13 |
but the force balance is also behind the incipient movement of sediment grains even though the local small turbulence may be very chaotic (stochastic).
July 16, 2013, 19:43 |
#9 |
michael barkhudarov
Rep Power: 18 |
Not quite. Particles are tracked as Lagrangian bodies using the 2nd Newton's law. Sediment is tracked as continuum, so there will be differences. Particles do not interact with each other, only with fluid. For example, particles do not pack and form packed bed.
July 19, 2013, 09:15 |
#10 |
Zeregaber Moghes
Rep Power: 13 |
The results along with your explanation clearly depicts that the use particles in place of sediment to understand the starting movement of sand grains is impossible.
July 29, 2013, 18:19 |
#11 |
Jeff Burnham
Rep Power: 17 |
If you wish to study forces acting on a single particle, consider using 'general moving object' physics. The scale of the model will be very small so that one or two individual grains are resolved. Then you can look at angularity, resting orientation, etc.
dispersion model with lagragian particle tracking model for incompressible flows | eelcovv | OpenFOAM Running, Solving & CFD | 54 | April 10, 2018 10:36 |
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump | scatman | CFX | 7 | January 8, 2018 01:59 |
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message | peteryuan | OpenFOAM Installation | 6 | August 18, 2013 19:00 |
Particle tracking prob, urgent. | sakurabogoda | CFX | 1 | March 11, 2013 22:11 |
Number density tracking rather than particle tracking | Rebecca | Main CFD Forum | 2 | April 23, 2009 13:52 |
