Home > Forums > Software User Forums > FLOW-3D
Making pretty simulations :P
Old   April 2, 2013, 13:38
Default Making pretty simulations :P
unknowntothem is on a distinguished road
I have searched the forum so apologies if this has already been covered but how does one export results to a visual software package such as 3D studio max? I want to present my findings for a uni project in an animation where the original model is presented photo-realistically.
unknowntothem is offline   Reply With Quote
Old   April 6, 2013, 23:59
Jeff Burnham
JBurnham is on a distinguished road
FLOW-3D writes an .stl file when you do a 3-D plot. You can plot the fluid surface, the solid surface, or both together, on the Analyze tab. See the tutorials in the User Manual for explanation of how to use the Analyze tab. The iso-surface is written to the simulation directory, and it's named iso000001.stl, or .f3d, or something like that. In any case, you can use it as an approximate fluid surface for import to other programs. More accurate surfaces need to be exported as text data and then meshed into an .stl in another program.
JBurnham is offline   Reply With Quote
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
