March 25, 2013, 12:24 |
FLOW3D model spontaneously explodes
Simon
Rep Power: 14 |
My FLOW3D model spontaneously became unstable after happily chugging away for 2 days. Analysis of flow fields prior to the explosion showed nothing amiss. I was solving for the long-term mixing resulting from a quasi-steady-state jet injecting fluid into a stratified reservoir. The velocity field developed within the first 10% of the model, and the remaining simulation is to capture the gradual temperature mixing. Thus, I am perplexed why the model suddenly became unstable.
My question is: Are there any important tips/tricks I should use to avoid spontaneous instabilities? And if the solution becomes unstable and blows up, are there any important tips/tricks for diagnosing/fixing the model? Thanks! (For reference, here are my solver settings... Pressure: Implicit, GMRES. Viscous Stress: Explicit. Heat transferL Explicit. Advection: Explicit. Momentum: 1st Order. Turbulence: RNG) |
March 25, 2013, 14:06 |
Rep Power: 14 |
One thing to watch for is the size of the maximum residual from the implicit pressure solver. The convergence criterion for this solver is [usually] inversely proportional to the time step size, so if the time step drops the convergence criterion can become large. If it remains large for too long it will yield a poorly converged solution.
Check if there is a sudden increase in the maximum residual near the time that the results become unreasonable. If so, try reducing the convergence criterion multiplier (epsadj) or changing to a constant convergence criterion (epsi). |
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 03:08 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
LES and combustion model | Margherita Cadorin | CFX | 0 | October 29, 2008 06:24 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 04:27 |
Ocean Wave Model with FLOW3D | Haryo Armono | Main CFD Forum | 0 | January 28, 1999 14:11 |
