Bala
Rep Power: 17 ![]() |
Dear all,
I am working in a problem that 2 cylinders are separated by some distance with different fluids (and different level also) undergoing acceleration and rates together. I am unable to add 2 different fluid in 2 cylinder and level also. Please someone help me out to solve this prob. |
Rep Power: 14 ![]() |
If they are not connected you rarely need to simulate them together, so just reduce the domain to model each container.
If they are connected or need to be simulated together for some other reason you can use the scalar model to modify the fluid properties in one container. |
two fluids |
How to add a source term (body force) to icoFoam? | chris Liu | OpenFOAM Programming & Development | 4 | October 27, 2014 15:38 |
Fluid Structure Interaction | Apollo | FLUENT | 8 | July 7, 2004 17:54 |
Non-newtonial Fluid | Henry | CFX | 1 | October 23, 2002 13:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid hot volume in fluid cold volume | zahid | FLUENT | 4 | June 1, 2002 09:11 |
