September 30, 2012, 11:41 |
embedded air in a thin shell
I want to simulate the flow behavior of mortar (density of about 2100 kg/m³) in a very thin walled shell. Depending on how the mortar flows into the shell (e.g. volume flow rate) air is embedded in the mortar. How can I model the air in the shell? The density ratio between mortar and air is more than 2000. Does the 2 fluid-model make sense? |
2 fluids, air, mortar |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 06:59 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
shell conduction @ thin walls | Jiri Beran | FLUENT | 0 | May 18, 2008 15:08 |
Plastic Flow, thin shell type | Dave Pinella | Main CFD Forum | 0 | December 4, 2001 10:27 |
