Home > Forums > Software User Forums > FLOW-3D
Particle Transport in Fluid Stream. How to keep them in the fluid!
Old   August 9, 2012, 10:08
Default Particle Transport in Fluid Stream. How to keep them in the fluid!
kavanaa1 is on a distinguished road
Hi All,
I am modelling the tranport of particles in a falling fluid stream. Having a problem as the particles are jumping out of the stream (see attached screenshot1)
Are there any settings I can change to ensure the particles are retained within the fluid stream? (see screenshot 2 for current settings)
Appreciate your time.
Alan
kavanaa1 is offline   Reply With Quote
Old   August 29, 2012, 17:26
dmilano is on a distinguished road
On the Particles dialog make sure that the "Particles cannot escape to voids" option is checked. I think it is by default, so this looks more like a display quirk. The 3D view draws a surface of constant fluid fraction (0.5 by default). You may have particles in regions where the fluid fraction is less than 0.5, so the fluid surface is not drawn. On the Analyze->3D tab, try reducing the contour value - I suspect that this will display fluid around the particles.
dmilano is offline   Reply With Quote
Old   September 19, 2012, 01:13
Default how to keep particles in fluid region in CFX?
sara
sarasj is on a distinguished road
hi all
I am simulating particles in an open channel (air and water) and I inject particles from bottom boundary, but particles move out from fluid (water) into air?
can you please help me to solve this problem?
thanks
sarasj is offline   Reply With Quote
Particle transport and deposition & Drift Flux Model Peter023 Fluent UDF and Scheme Programming 3 April 21, 2021 00:50
Initialize Particle Transport Model Jene CFX 3 September 1, 2004 16:43
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
Re: particle transport in pipes Zhiming Zhao CFX 1 May 9, 2001 23:15
PARTICLE TRANSPORT WITH CFX I.I. CFX 1 September 24, 2000 03:57
