Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Solidworks Flow Simulation, Problem with Point Goals
Old   February 7, 2012, 08:46
Default Solidworks Flow Simulation, Problem with Point Goals
Tom Steventon
TomSteventon is on a distinguished road
I am currently attempting to run a CFD simulation on a 3D model imported from Catia. The file type I have imported it as is a stp solid which solidworks then converted to a .sldprt. In Catia it was originally drawn as a skin and then filled to produce a solid.
The problem I am having is that whenever I try and set point goals on vertices on the models it comes up with the following error message:
"Please specify only solid parameters for this point"
Having had a look through the forums, this problem only tends to crop up when you are trying to set a point goal in the middle of the working fluid.
It is more than happy to set a surface goal but will not allow me to set up a point goal, any help on this matter would be greatly appreciated.
Tom
TomSteventon is offline   Reply With Quote
Old   February 7, 2012, 10:37
Disabled
Boris_M will become famous soon enough
Hi Tom,
what is the parameter you want to specify for this goal?
What is your simulation setup (external, internal)?
Is the vertice on a solid edge with contact to the fluid volume?
Make sure there is a fluid volume, if you use "Exclude cavitites without flow conditions" and use a small cavity in which you haven't selected a fluid subdomain then there is no fluid volume.
Boris
Boris_M is offline   Reply With Quote
Old   February 8, 2012, 12:02
Tom Steventon
Thankyou very much Boris, the problem was with the analysis being an internal flow, when I specified an external flow (which is what it probably should have been in the first place...) it happily accepted the point goals.
Thanks for your help
Tom
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 19:30
Centrifugal Pump Simulation Problem! warex FloEFD, FloWorks & FloTHERM 29 September 23, 2014 11:27
HVAC Solidworks Flow Simulation milasko FloEFD, FloWorks & FloTHERM 9 August 11, 2014 03:58
the problem of my transient simulation "Floating point exception: Overflow " alloveyou CFX 15 November 22, 2012 12:14
Non-steady flow simplified for use in Vissim steamerandy Main CFD Forum 0 October 31, 2011 22:08
