December 1, 2011, 21:03 |
Multi Species Flows in a mixing tank
colin
Rep Power: 15 |
Can FloEFD simulate the residence time of chlorine in a dosing tank and specify the contact time or residence time. Is there a metric or equivalent for this.
January 16, 2012, 16:49 |
Disabled
Rep Power: 24 |
Hello DrBidden,
basically you can simulate mixtures of fluids transiently and monitor the mass or volume fraction of a fluid and therfore know at what time the fraction has reached a certain value. I don't really know what th contact time is or what it means. Maybe if you could explain what your task is, I could better judge if FloEFD can help you. Something that might relate to what you need is the LMA (Local Mean Age) basically telling you how well a certain volume is vented, such as a room. Regards, Boris |
January 16, 2012, 20:50 |
Thanks
colin
Rep Power: 15 |
Hi Boris
Thanks for your reply. LMA would help I guess if that is a metric available in FloEFD. I do not have the HVAC module which probably includes this metric. I am doing a particle study and then doing a statistical analysis to obtain my own residence time criteria. |
January 17, 2012, 02:51 |
Disabled
Rep Power: 24 |
Yes, LMA is available in FloEFD. You will have to go into the calculation control options and there you'll find it in the advanced tab. This needs to be switched on before calculating as it has to be calculated with the flow. Then you can select it after the solver is finished in the parameter list for visualization.
I think it should be available without HVAC module but I cant remember. Another feature and better suitable than particles are the tracers. This is a new post processing feature which allowes you to calculate contaminant distribution in the post processing. It basically uses the existing flow field to calculate the distribution of a contaminant, also over time with a steady state simulation. But for that you'll need the HVAC module. Boris |
concentrations, multi-species |
3D mixing tank using MRF/SRF | cfd_confuse | Main CFD Forum | 1 | September 13, 2016 03:43 |
Steady state multi species | Hrushi | OpenFOAM | 20 | April 7, 2015 06:31 |
3D mixing tank using MRF/SRF | cfd_confuse | FLUENT | 0 | October 2, 2010 04:46 |
Mass conservation problem in mixing tank multiphase simulation | rockewan | FLUENT | 0 | April 6, 2010 13:34 |
HELP: User subroutines for multi species system | sherry | Siemens | 0 | October 8, 2004 12:08 |
