June 16, 2011, 11:14 |
Heat Sources
Chris
I am currently trying to work out the effects on my 128 heat sources. Do i have to create 128 individual Heat Geneation Rates for each 1 ?? It seems i do but i am hoping there is a way around this. When i just do them as a lump i dont get the results i want or it doesnt seem to treat them as indiviudals. |
June 28, 2011, 13:25 |
Disabled
Rep Power: 24 |
Hello Hutch,
no, this is not necessary. When you have 128 heat sources with each the same amount you can simply select them all and creat a single source with 128 times the value and it will be distributed evenly on each selected item. If that doesn't work properly please contact your support and let them check your issue. Boris |
floefd pro 9 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 06:57 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 23:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
Time Dependent Heat Sources | Leon Mills | Phoenics | 1 | July 3, 2001 06:22 |
